Sengled LED Zigbee Bulbs Reporting On When Off
Hi everyone, I recently added 5 Sengled Smart LED Zigbee bulbs to my system. The bulbs are part of two groups, with 3 in one group and 2 in the other. While the setup seemed straightforward, I’ve encountered an odd issue where the group devices on my dashboard display as ‘on’ even when none of the bulbs in that group are physically lit. This has been happening randomly, and I’m curious if anyone else has faced a similar problem or found a solution.
Looking into the device events, I noticed that one bulb shows as turned on, causing the group device to switch to ‘someOn’ state. Shortly after, another bulb in the same group triggers an event, changing the group state to ‘allOn’. However, physically, the bulbs remain off. I’ve tried adjusting my Wi-Fi channel to 6 and set my Zigbee hub to channel 25, but this didn’t resolve the issue. I’m hoping someone in the community has encountered this and can offer advice or a workaround. Thanks in advance for any help!
