Sensors exposed differently depending on hub?
The same type of sensor (the discontinued TVOC sensor) is exposed differently depending on hub.
Attached are two pictures.
First hub is the M100 - exposed to Apple home via matter. This exposes the TVOC sensor as a 3 accessory device, showing temperature, humidity and air quality.
Second hub is the M1S - also exposed to Apple home via matter. But exposes the TVOC sensor as a singular device only appearing as an air quality sensor.
Can someone explain this and can Aqara fix this? I need the humidity sensor exposed.
I’m currently using a spare E1 hub just to expose devices over the HomeKit connection rather than matter just for devices with discrepancies…
@craigbarnes That’s a really interesting discrepancy you’ve caught, and I can see why it’s frustrating—especially when you’re having to juggle a spare E1 hub just to get consistent behavior across your setup.
From what I can gather, this looks like a firmware-level Matter bridge implementation difference between the M100 and M1S rather than an Apple Home quirk. The M100 appears to be properly decomposing the TVOC sensor’s composite data (temperature, humidity, and air quality/VOC index) into separate Matter endpoints, while the M1S is only surfacing the air quality cluster.
A few things that might be worth checking:
  • Firmware parity: Are both hubs running the latest firmware? Sometimes newer hubs like the M100 get updated Matter bridge capabilities before older ones catch up.
  • Matter spec support: The M100 is positioned as a more current Matter controller/bridge, so it may implement a broader device type mapping. The M1S Gen 2 does support Matter, but the original M1S’s Matter bridge implementation might be more limited in how it handles multi-sensor accessories.
That said, the reference info I have on hand doesn’t drill into this specific hub-to-hub sensor exposure variance for the TVOC device. This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.[“content_id”:7"]
For getting this sorted—or at least properly logged as a bug/feature gap—I’d recommend reaching out directly:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
Your workaround with the E1 hub over HomeKit is clever, though definitely not ideal long-term. If you do get an official response on whether this is a known limitation or planned fix, it’d be great to hear back—this kind of granular detail really helps the community.
Your second screenshot already has a “Current Relative Humidity” row, even though Apple Home presents it as a single accessory. Is the missing piece the humidity value itself, or being able to select it as a trigger or condition in an automation? Those would be different problems to investigate.
Could you also confirm which M1S generation you have and the firmware versions on the M1S and M100? The screenshots show different layouts, but I would not assume from the accessory count alone that the humidity measurement is absent. It would help to compare what each device offers in the automation editor before changing the bridge setup.
Thanks for the response.
I did suspect this was to do with the age of the M1S Gen 2 having an older hardware limitation.
I can confirm both are on the latest firmware I have access to.
The M1S specifically is on version 4.5.30_0013.0013
I’m happy to log it with the Aqara team - just to see if this is something that can be fixed. I do quite like the M1S as it works like a powerhouse hub as mine has almost 50 devices connected, it’s managing my whole upper floor flawlessly.
However long term I suspect I’ll be replacing this device with the M410 when that comes out, which may actually resolve this issue also being a newer matter spec - the replacement would mostly be as I would need the M410 regardless as the camera hub.
@craigbarnes Appreciate the follow-up, Craig! Good to know both hubs are on the latest available firmware — that rules out an easy fix and pretty much confirms this is a Matter bridge implementation gap on the M1S Gen 2 side rather than a config issue on your end.
Your instinct about hardware/generational differences seems spot-on. The M100 and newer hubs are built with more current Matter controller specs, while the M1S Gen 2 — capable as it is — may have Matter bridging limitations that simply can’t be fully resolved through firmware alone. It’s impressive that yours is handling ~50 devices so smoothly; the Zigbee side is clearly rock solid.
Logging it with the team is the right move. Even if it’s a known architectural limitation, getting it officially documented helps with transparency — and who knows, sometimes these gaps get addressed in ways that surprise us.
The M410 upgrade path makes sense too, especially since you’d need the camera hub functionality regardless. Newer silicon usually means fuller Matter spec compliance, so there’s a decent chance that resolves the multi-sensor exposure issue outright.
If you do hear back from support — whether it’s a “won’t fix” for M1S or something queued for a future update — would love if you shared the response here. These hub-to-hub behavioral differences are exactly the kind of detail that trips up other users, and your E1/HomeKit workaround is already a useful data point for the community.
Fingers crossed for a satisfying answer from the team! :crossed_fingers:
That’s the most frustrating part - that it clearly has exposed humidity.
But I seem to be unable to interact with that data - it’s not selectable as a trigger point in automations and does not appear anywhere in home unless you specifically go into the device settings like this.
My M1S is the Gen 2 model and its firmware is 4.5.30_0013.0013.
Although it’s disappointing that I’m running several hubs to get this specific sensor point into home, it’s not the end of the world.
I mostly have the M1S to be a siren and a hub.
Seeing as I’ll need the M410 for the camera hub, assuming it works as a device hub also, as it also has a siren I’m hoping to replace the M1S with the M410 - which on the latest matter software (I assume) may also resolve this problem.
That distinction is useful for the support ticket. I would describe it as humidity being readable in the accessory settings but unavailable as an automation trigger, rather than as a missing humidity measurement. Include a screenshot of the trigger picker alongside the accessory details, the TVOC model, M1S Gen 2 firmware 4.5.30_0013.0013, the exact M100 firmware and your iOS version. Ask Aqara to compare that specific TVOC automation capability through both Matter bridges.
I would also ask them to confirm TVOC humidity-trigger support on the M410 before moving your existing devices. A newer Matter version alone would not establish that this particular behaviour is fixed. Your E1 route gives you a useful working comparison while they investigate, without having to rebuild the M1S setup just to test an assumption.
