I recently embarked on a project to set up Node-Red, InfluxDB, and Grafana on my Raspberry Pi 3 to monitor various data points like power usage, temperature, and humidity from my Hubitat ecosystem. While the process was quite involved, I wanted to share my journey and some tips for anyone looking to undertake a similar project.
Getting Started
I started with a fresh installation of Raspbian Buster Lite on my Raspberry Pi 3, opting for the Lite version to reduce the load on the system. The first step was installing build essentials and Node-Red. Following the official Node-Red documentation, I ran the installation script and configured it to start as a service. This part went smoothly, and I was able to access Node-Red via the web interface.
InfluxDB Installation
Next, I moved on to setting up InfluxDB. I followed the official installation guide, adding the InfluxDB repository to my sources list and installing the package. However, I encountered an issue where InfluxDB wouldn’t start properly. After some troubleshooting, I realized that the data directory permissions needed adjustment. I created a dedicated data folder and ensured the correct permissions were set, which resolved the issue.
Grafana Setup
With InfluxDB up and running, I proceeded to install Grafana. Using the official Debian package repository, I downloaded and installed Grafana. Configuring it to start on boot was straightforward, and I could access the Grafana web interface shortly after. I set up an admin account and configured the InfluxDB data source, pointing it to my Raspberry Pi’s static IP address.
Integration with Hubitat
Now came the exciting part—integrating everything with my Hubitat setup. I used Node-Red to create flows that would send data from my Hubitat devices to InfluxDB. I installed the necessary Node-Red nodes, such as node-red-contrib-influxdb, and configured them to write data to my InfluxDB instance. After some trial and error, I managed to get the data flowing into InfluxDB and visualized it in Grafana using custom dashboards.
Challenges and Solutions
One of the main challenges I faced was ensuring all services started correctly on boot. I had to configure systemd services for Node-Red, InfluxDB, and Grafana, and make sure they were enabled. Another hurdle was getting the data from Hubitat into Node-Red. I had to adjust the WebSocket connection settings to match my Hubitat setup accurately.
Tips for Success
- Static IP Address: Configure a static IP address for your Raspberry Pi to avoid connection issues, especially when accessing services from other devices on your network.
- Data Directory Permissions: Ensure that the InfluxDB data directory has the correct permissions to prevent startup issues.
- Regular Backups: Set up regular backups for your InfluxDB data to prevent data loss.
- Documentation: Keep detailed notes of your installation and configuration steps. This will be invaluable for troubleshooting and future reference.
Setting up Node-Red, InfluxDB, and Grafana on a Raspberry Pi 3 was a rewarding experience. It allowed me to create a robust system for monitoring and visualizing data from my Hubitat devices. While there were some hurdles along the way, persistence and careful troubleshooting paid off. I highly recommend this setup to anyone looking to dive deeper into home automation and data visualization.
If anyone has questions or needs assistance with their setup, feel free to reach out! Happy automating! ![]()
