Setting Up Outdoor Motion Sensors and Lights with Homematic
Hi everyone, I’m looking to set up an outdoor motion sensor and light using my Homematic system. I have a CCU2 and I’m planning to connect a 24V motion sensor to it. I’ve heard that the HMW-IO-12-SW7-DR module is a good option, but I’m not entirely sure. I also want to connect the sensor to a light that will turn on when motion is detected, especially in low-light conditions.
I have a few questions:
  1. Which Homematic module should I use for the motion sensor?
  2. How do I connect the sensor’s outputs to the Homematic module?
  3. How do I set up the automation rule so that the light turns on when motion is detected and it’s dark outside?
  4. Are there any safety precautions I should take to protect the Shelly module from moisture or potential shorts?
Any advice or tips would be greatly appreciated! Thanks in advance.
