Setting Up Vera Lite with Yale Z-Wave Deadbolt and Mi Temp Thermometers
Hey everyone, I wanted to share my recent experience setting up a smart home system using Vera Lite, a Yale Z-Wave deadbolt, and a few Mi Temp thermometers. It’s been a fun journey, but I hit a few bumps along the way that I thought I’d document here in case others run into similar issues.
First off, the Vera Lite has been a great hub for my setup. It’s reliable and the interface is user-friendly. I paired it with a Yale Z-Wave deadbolt, which I’ve been really impressed with. The integration with Vera was seamless, and I love being able to monitor and control the lock remotely. However, one thing I wanted to track more closely was the activity logs—specifically, which PIN was used to unlock the deadbolt and whether it was locked or unlocked. Initially, the logs on the Vera portal were a bit too vague for my liking, just showing that some activity occurred without much detail.
After a bit of research, I discovered that Vera does support more detailed logging through its settings. I had to dig into the configuration menu, but once I found it, I was able to enable more granular logging for the deadbolt. Now, I can see exactly which PIN was used and whether the lock was engaged or disengaged. This has been super helpful for keeping track of access, especially since we’re using this system in a rental cabin.
Another part of my setup that I wanted to mention is the Mi Temp thermometers. I have three of them, and I wanted to connect all of them to a single Vera add-on. At first, I was a bit confused because only one thermometer showed up in the Vera interface. After some trial and error, I realized that I needed to adjust the pairing settings in Vera. Once I did that, all three thermometers showed up, and I could monitor the temperatures in different areas of the cabin simultaneously. It’s been a lifesaver for ensuring the cabin stays at a comfortable temperature year-round.
For anyone else setting up a similar system, here are a few tips I’ve picked up along the way:
  • Take Your Time with Pairing: Z-Wave devices can sometimes be finicky, so make sure you follow the pairing instructions carefully. If you run into issues, double-check your Vera settings and ensure that the add-ons are properly configured.
  • Explore Vera’s Logging Options: Don’t settle for the default logs if they don’t provide enough detail. Vera has some pretty robust logging features that can give you a much clearer picture of what’s happening with your devices.
  • Test Everything Thoroughly: Before relying on your system for something as important as security, test all your devices and automations extensively. It’s better to catch any issues during setup than to find out the hard way that something isn’t working as expected.
Overall, I’m really happy with how my smart home setup has turned out. It’s given me peace of mind knowing that I can monitor and control the cabin from anywhere, and it’s been a great learning experience. If anyone has any questions or runs into similar issues, feel free to reach out—I’d be happy to help!
Cheers,
Russ
