Shelly 1 PM Gen 4 Zigbee Configuration Help
Hey everyone, I’m trying to set up my new Shelly 1 PM Gen 4 sensor and I’m having a bit of trouble getting it to work properly in Zigbee mode. I’ve heard great things about this device, but I’m hitting a snag during the setup process. Let me share what I’ve done so far and where I’m stuck.
First off, I decided to use the Zigbee mode for this sensor because I already have a robust Zigbee network set up with Zigbee2mqtt. I followed the instructions to put the device into Zigbee mode by holding down the reset button for 5 seconds. The LED started flashing, which I think means it’s in pairing mode. I then tried to add it to my Zigbee network using the coordinator, but it didn’t seem to pick up the device. I tried this a couple of times, resetting and attempting to pair each time, but no luck.
Now, I’m a bit confused about whether I need to connect to the Shelly’s web interface first. I’ve heard that sometimes you need to access the device’s settings before it can be paired. I tried connecting to the Shelly’s network via my phone, but I’m not entirely sure how to navigate the settings to enable Zigbee mode properly. Is there a specific configuration I need to set before attempting to pair it again?
I’d really appreciate any advice or tips from anyone who’s successfully set up a Shelly 1 PM Gen 4 in Zigbee mode. Maybe I’m missing a step in the process, or perhaps there’s a trick to getting it recognized by the coordinator. If anyone has a step-by-step guide or can point me in the right direction, I’d be super grateful!
Fingers crossed someone can help me out here. I’m really excited to get this sensor working as part of my smart home setup, and I’m sure it’ll be a great addition once everything is up and running. Thanks in advance for any assistance you can offer!
