Shelly and Home Assistant Integration Success Story
I’ve been diving into the world of smart home automation for the past few months, and I’m absolutely thrilled with how far I’ve come! My journey started with a simple goal: to replace my traditional light switches with something more modern and efficient. After researching various options, I decided to go with Shelly devices paired with Home Assistant. The combination has been nothing short of amazing!
The Challenge
Initially, I faced a bit of a puzzle. I have two light switches controlling a single lamp, but the setup was problematic. The lamp would only light up briefly, and the switches seemed to conflict with each other. After some digging, I realized the issue was with the wiring and the lack of a neutral wire in one of the switch boxes. This made it impossible to use traditional smart switches without rewiring everything, which wasn’t feasible given the walls were already closed.
The Solution
Enter Shelly 1PM and Home Assistant! I decided to swap out the old switches with Shelly’s smart relays. The process was straightforward: install the Shelly devices, configure them in Home Assistant, and set up the necessary automations. The best part? No need for additional wiring or drilling through walls!
The Setup
Here’s a quick rundown of what I did:
  • Shelly 1PM installed in each switch box.
  • Configured both devices in Home Assistant to control the same lamp.
  • Set up automations so that toggling either switch would turn the lamp on or off.
  • Added scene automation for bedtime routines, where the lamp dims gradually before turning off.
The Outcome
The result? Seamless control of my lamp from either switch! No more brief flickers or conflicts. The integration with Home Assistant has also opened up a world of possibilities, like voice control through Google Home and scheduling the lamp to turn on at specific times.
Tips for Others
If you’re considering a similar setup, here are a few tips:
  1. Plan Ahead: Sketch out your wiring and device placements before making any physical changes.
  2. Take It Step by Step: Don’t try to automate everything at once. Start with basic controls and gradually add more features.
  3. Leverage the Community: The Home Assistant and Shelly communities are incredibly supportive. If you run into issues, don’t hesitate to ask for help!
This project has been a fantastic learning experience and a huge confidence booster for my smart home journey. It’s amazing how a little creativity and the right tools can transform something as simple as a light switch into a fully integrated smart home component. If you’re on the fence about making the switch to smart devices, I highly recommend starting small and building from there!
Thanks to everyone in the community for their invaluable guidance and resources. Here’s to many more smart home adventures! :rocket::bulb:
