Shelly BLU TRV Zigbee Integration Success Story
I’ve recently had the pleasure of successfully integrating my Shelly BLU TRV Zigbee thermostat into my home automation setup, and I wanted to share my experience with the community. While the initial setup was a bit of a challenge, the end result has been absolutely worth it!
The Challenge:
At first, I encountered some issues with getting the Shelly BLU TRV to fully integrate with my system. Although the device paired successfully with zigbee2mqtt and the interview process seemed to complete without issues, I couldn’t quite get all the features working as expected. The thermostat was visible in my system, but certain functions like temperature adjustments and manual mode weren’t responding as they should.
The Solution:
After doing some research and reaching out to the community, I discovered that ensuring the device was running the correct firmware version was key. I also realized that a more thorough configuration in Home Assistant was necessary. By carefully setting up the Lovelace cards and ensuring that the device was properly exposed in the frontend, I was able to unlock all its functionality.
The Payoff:
Now, my Shelly BLU TRV is a seamless part of my smart home setup. It’s incredibly responsive, and the temperature controls work perfectly through both the Shelly app and Home Assistant. I’ve even set up some simple automations to adjust the temperature based on my daily routines, which has made my mornings and evenings much more comfortable.
Tips for Others:
If you’re looking to integrate a Shelly BLU TRV into your system, here are a few tips that might help:
  • Ensure your device is running the latest firmware.
  • Take the time to properly configure your Lovelace cards in Home Assistant.
  • Experiment with different Lovelace themes to find the one that best matches your setup.
  • Don’t hesitate to reach out to the community if you run into any issues—there are plenty of helpful folks here willing to lend a hand!
Overall, I’m thrilled with how this integration turned out. It’s a great example of how a little patience and persistence can lead to a fantastic smart home experience. If anyone else is working on integrating their Shelly BLU TRV, feel free to reach out—I’d be happy to share more details or help troubleshoot any issues you might encounter!
Cheers,
