Hey everyone! I wanted to share my recent experience integrating my Shelly devices with Homey Pro. I’ve been using Shelly devices for years, controlling them through the Shelly app, but I’ve always wanted to bring them into a more integrated smart home ecosystem. Homey Pro seemed like the perfect fit, but I wasn’t entirely sure how to make the transition smoothly.
After some research and a bit of trial and error, I found the solution! Here’s how I did it:
Preparation: I made sure all my Shelly devices were updated to the latest firmware. This step is crucial because it ensures compatibility with new integrations.
Integration Setup: I discovered that Homey Pro supports Shelly devices through its built-in integrations. No need for extra apps or complicated workarounds! I simply went to the integrations section in the Homey app and enabled the Shelly integration.
Device Pairing: Once the integration was enabled, I followed the on-screen instructions to pair each Shelly device. It was surprisingly straightforward—just a matter of holding down the button on each Shelly device until they were recognized by Homey.
Automation Magic: After all my devices were successfully paired, I started creating automations. The possibilities are endless! For example, I set up my Shelly switches to automatically turn on my hallway lights when motion is detected in the evening. It’s making my home smarter and more convenient every day.
I’m thrilled with how seamless the integration process was. It took a bit of time, but the end result is worth it. If you’re considering integrating Shelly devices into your Homey setup, I highly recommend giving it a try! You’ll be amazed at how much more connected your home can feel.
Happy integrating everyone! ![]()
