Shelly Dimmer 2 Installation and Zigbee Setup Tips
Hey everyone, I wanted to share my recent experience installing the Shelly Dimmer 2 and setting it up with Zigbee in Home Assistant. It’s been a fantastic addition to my smart home setup, but I did run into a few hiccups along the way that I thought I’d document here in case others are facing similar issues.
First off, the installation process was straightforward. I replaced my existing wall switch with the Shelly Dimmer 2, and it fit perfectly. The setup via the Shelly app was seamless—just a matter of scanning the QR code and letting the app do its thing. Pairing it with my Zigbee hub was equally smooth, and within minutes, it was fully integrated into Home Assistant.
However, I did encounter a minor issue where the dimmer wouldn’t report state changes back to Home Assistant after a few weeks of flawless operation. After a bit of troubleshooting, I realized it was a matter of resetting the device and reconfiguring the CoIoT settings. Ensuring the device was discoverable and adjusting the network settings properly did the trick. It’s a good reminder to check these settings periodically, especially if you notice any connectivity issues.
One feature I particularly love is how the Shelly Dimmer 2 handles brightness adjustments. It’s incredibly smooth and responsive, making it a pleasure to use. I’ve also been experimenting with creating custom scenes in Home Assistant, combining the dimmer with other smart devices like my Philips Hue lights and smart plugs. It’s amazing how much you can automate once everything is connected.
Now, moving on to my next project: expanding my Zigbee network. I’ve got a few more devices I’d like to add, including some sensors and switches. Has anyone had success integrating non-Shelly Zigbee devices into Home Assistant? I’d love to hear any tips or potential pitfalls to avoid. Also, if anyone has experience with creating complex automations using multiple Zigbee devices, I’d be grateful for any advice!
In closing, I’d highly recommend the Shelly Dimmer 2 to anyone looking to upgrade their home lighting setup. It’s reliable, easy to set up, and integrates beautifully with the broader smart home ecosystem. Happy tinkering, and I look forward to hearing about your projects too!
