Shelly Dimmer LED Blinking Issue
Hi everyone, I recently got my hands on a Shelly Dimmer and installed it in my home. The setup process went smoothly—connecting it to my WiFi, configuring it, and calibrating it all worked out just fine. However, I’ve encountered a peculiar issue that I’m hoping someone can shed some light on.
When I dim the light from full brightness (18W) down to around 10W, the LED starts to blink. Interestingly, once it goes below 10W, the dimming works perfectly without any blinking, all the way down to 0.7W. The LED is supposed to be dimmable, so this behavior is a bit puzzling.
I’ve tried adjusting the dimming curve and checking the firmware for any updates, but nothing seems to resolve the issue. I’m curious if this is a known problem or if there’s a workaround that others have discovered. Any insights or suggestions would be greatly appreciated!
Looking forward to hearing from you all. Thanks for your help!
