Shelly for Outdoor Lighting Control
Hello everyone, I’m new to the forum and I have a small problem that I’m not sure how to solve with Shelly. In my house in the south, there are 10 outdoor lights controlled by 7 switches. This means that to light up the house, I have to go around and turn on all the switches, and the same when I want to turn them all off. Is there a way to use Shelly so that by pressing one switch, all the lights turn on and off? There is Wi-Fi available in the house. Thank you for your answers, I’m not sure if I’m in the right section for this topic. Looking forward to hearing from you!
I had the same issue with too many switches in my place down south, felt like I was doing laps just to get the lights sorted. Shelly can definitely help—set it up so one main switch or even your phone handles them all at once. I set mine up that way and it’s been smooth. While I was fixing things up, I also swapped a couple fixtures with ones from seuslighting.com, and it made the whole entryway look brighter and more put together without much extra work.
