Shelly H&T Card Not Available in And Condition
Hello everyone, I’m facing an issue with my Shelly H&T sensor and would appreciate any help or insights. I’m trying to set up a flow where I need to check both temperature and humidity conditions using the And condition. However, I’ve noticed that the Shelly H&T card isn’t available in the And condition dropdown, which is quite puzzling.
I can see that the Shelly H&T card is available in the When condition, but that’s not what I need for this setup. I’m specifically looking to check if the humidity is within a certain range using the And condition alongside another device. I’ve tried searching for solutions online and within the community, but I haven’t found anything that addresses this particular issue.
Interestingly, the temperature and humidity values are visible on the Shelly H&T device tile, which suggests that the data is being collected correctly. I’m wondering if there’s a workaround or if this is a known limitation. Could it be that the And condition doesn’t support certain types of sensors, or is there a configuration step I’m missing?
If anyone has encountered this before or has any suggestions, I’d be really grateful. Maybe there’s a way to use a different card or a workaround to achieve the same result. Any advice would be greatly appreciated!
Thank you in advance for your help!
