Shelly H&T Sensor Update Issue and Resolution
I recently installed a Shelly H&T sensor into my Home Assistant setup, and I noticed that while the sensor works perfectly on Shelly Cloud, it wasn’t updating in my HA instance. This was a bit puzzling since I was using the latest version of HA (2022.11.2) as a Docker container. After some research and troubleshooting, I found that the issue might be related to how the sensor data is being pulled into HA. I reached out to the community for help, and someone suggested checking the integration settings and ensuring that the sensor was properly configured. Turns out, there was a minor configuration tweak needed, and once I adjusted it, everything started working smoothly! It’s amazing how a small change can make such a big difference. If anyone else is experiencing similar issues, I’d recommend double-checking your integration settings and reaching out to the community if needed. Happy automating! :rocket:
