Hi everyone! I wanted to share some insights and experiences from my journey with smart home automation. First off, I’m a huge fan of Shelly devices—they’ve been rock solid in my setup for years. I recently came across a question about the Shelly DB2024R_XSM compatibility with Home Assistant. From what I understand, it should work seamlessly with the native Shelly integration, but if you’re experiencing issues, double-checking the firmware and ensuring proper network connectivity is always a good first step. The Shelly community is super supportive, so don’t hesitate to reach out if you hit any bumps!
Another topic that caught my attention was the automation setup using two sensors—a door/PIR combination. I’ve been brainstorming similar scenarios myself. The key here is to use a sequence-based automation. In Home Assistant, you can achieve this by setting up a trigger that waits for the door sensor to activate first, then listens for the PIR sensor within a short timeframe. Adding a time condition (like sunset) ensures it only triggers when it’s dark. It’s a clever way to prevent false positives and keep things efficient!
Lastly, I wanted to mention the Govee Light Festival. If you’re into RGB lighting, this is a fantastic product for creating vibrant, dynamic lighting effects. I’ve been using it in my living room, and it’s been a hit during gatherings. The app controls are smooth, and the preset modes make it easy to set the mood without much hassle.
If anyone has similar setups or tips, I’d love to hear about them! Happy automating everyone! ![]()
