Shelly Motion 2: A Comprehensive Guide to Motion Detection in Smart Homes
Motion detection is a cornerstone of any smart home setup, and the Shelly Motion 2 has been a game-changer for me. After spending considerable time configuring and testing this device, I thought it would be helpful to share my experiences, tips, and solutions to common issues.
Setup and Initial Impressions
I installed the Shelly Motion 2 in my staircase, aiming to automate the lighting based on motion detection across three floors. The setup was straightforward—plug it in, connect it to my network via the Shelly app, and start configuring. The device detected motion almost instantly, and the built-in LED display made it easy to monitor its status.
Challenges Faced
However, things didn’t go as smoothly as I hoped. I encountered two main issues:
  1. Blind Time and Motion Detection Overlap
    • Initially, I set each motion sensor to trigger the lights and let them turn off after 2 minutes of inactivity. However, this led to an unintended consequence: if motion was detected near one sensor, it reset the timer for all connected sensors. This meant the lights stayed on longer than intended, especially if someone moved past multiple sensors in quick succession.
  2. False Alarms Due to Vibration
    • My staircase has a metal handrail, and the Shelly Motion 2 picked up vibrations from footsteps, triggering unnecessary alerts. I tried adjusting the sensitivity settings, but it didn’t completely solve the issue.
Solutions and Workarounds
After some research and experimentation, here’s how I resolved these problems:
  1. Blind Time Management
    • Instead of relying on the built-in blind time, I created a custom automation in my smart home system. When motion is detected, the lights turn on, and a timer starts. If motion is detected again before the timer completes, it resets. This ensures the lights stay on only when needed without overlapping timers.
  2. Reducing False Alarms
    • To tackle the vibration issue, I adjusted the sensitivity settings to the minimum. Additionally, I mounted the sensor slightly away from the handrail to reduce direct vibration impact. While this didn’t eliminate all false alarms, it significantly reduced them.
Tips for Optimal Performance
  • Placement Matters: Position the sensor away from areas prone to vibrations or drafts.
  • Custom Automation: Don’t rely solely on the device’s built-in features. Integrating with your smart home ecosystem can provide more control and flexibility.
  • Regular Updates: Keep the Shelly Motion 2 firmware updated to benefit from the latest improvements and bug fixes.
Despite the initial challenges, the Shelly Motion 2 has proven to be a reliable and versatile device. Its integration with smart home systems, combined with its motion detection capabilities, makes it a valuable addition to any setup. With a bit of tweaking and customization, it can seamlessly enhance your home’s automation.
If anyone has questions or needs help setting up their Shelly Motion 2, feel free to reach out! I’d be happy to share more details or troubleshoot issues together. :blush:
