I recently installed a Shelly Motion sensor in my home and wanted to share my experience and some tips for those who might be facing similar challenges. At first, I was puzzled when the sensor wouldn’t trigger my lights as expected. After some troubleshooting, I realized the importance of proper setup and configuration. Here’s what I learned:
Firmware Update: Ensure your Shelly Motion sensor is running the latest firmware. Outdated firmware can sometimes cause connectivity issues.
Integration with Hubitat: If you’re using Hubitat, make sure to install the correct drivers from the official GitHub repository. I had to double-check my installation process and ensure that the MQTT settings were correctly configured.
Testing the Setup: Use the Hubitat app to manually trigger the sensor and observe the logs. This helps identify if the sensor is detecting motion but not sending the correct signals to your automation system.
Automation Rules: Create a simple automation rule to test if the sensor can trigger an action. For example, have it turn on a light when motion is detected. If this works, you can gradually add more complex actions.
Location and Placement: The placement of your Shelly Motion sensor is crucial. Ensure it’s positioned to cover the desired area effectively and avoid false triggers from pets or objects.
If you’re still having trouble, don’t hesitate to ask for help in the community. We’re all here to learn and support each other! ![]()
