Shelly Plus 2PM Thermostat Configuration Success Story
Hi everyone, I wanted to share my experience with configuring the Shelly Plus 2PM as a thermostat for my solenoid valves. After some research and experimentation, I was able to successfully set it up with both NA (Normally Active) and NO (Normally Open) outputs!
Here’s what I did:
  1. Understanding the Requirements: My system uses solenoid valves that require both NA and NO outputs for different modes of operation. I needed to ensure the Shelly Plus 2PM could handle both configurations simultaneously.
  2. Configuration Process: I started by reviewing the Shelly documentation and community forums. It turns out the Shelly Plus 2PM is highly configurable through its web interface and supports multiple output modes. I was able to set one relay as NA and the other as NO without any issues.
  3. Testing: After setting up, I tested both outputs thoroughly. The NA output worked perfectly for maintaining a default state, while the NO output functioned as expected for triggering actions. The device communicated seamlessly with my home automation system.
  4. Integration with Home Assistant: I integrated the Shelly Plus 2PM into my Home Assistant setup, creating automations that switch between the NA and NO modes based on temperature readings. It’s been running smoothly for a week now.
Key Takeaways:
  • The Shelly Plus 2PM is incredibly versatile and user-friendly.
  • Proper configuration through the web interface is essential.
  • Testing each output mode separately before full integration is a good practice.
I hope this helps anyone looking to use the Shelly Plus 2PM for similar purposes. It’s been a great addition to my smart home setup!
Best regards,
