I recently embarked on a journey to upgrade my home’s lighting system using the Shelly Wall Kit, and I must say, it’s been a delightful experience. Let me share my journey and some tips for anyone considering a similar setup.The Setup I have a bedroom with a ceiling light and a table lamp, both of which I wanted to control seamlessly. The ceiling light is operated by a traditional wall switch, while the table lamp uses a smart bulb. My goal was to use the Shelly Wall Kit to control both the ceiling light and create a scene that would adjust the table lamp’s brightness through a cloud-based automation system.Challenges and Solutions Initially, I was unsure which Shelly device would be best suited for this setup. After some research, I decided on the Shelly 1 PM, which provided the necessary functionality to control both the ceiling light and integrate with my smart bulb. One challenge I faced was ensuring the wiring was correctly configured. The Shelly 1 PM requires Phase and Neutral connections, which I had available. I carefully followed the installation guide to ensure everything was set up safely and efficiently.The Outcome Once everything was set up, the transformation was remarkable. I can now control the ceiling light with one switch and trigger a pre-set scene with the other, which adjusts the table lamp’s brightness based on the time of day or my mood. This integration has made my bedroom feel more connected and user-friendly.Tips for Others - Plan Your Wiring: Ensure you have the correct wires available and properly labeled before starting the installation.- Read the Manual: While most devices are plug-and-play, taking the time to understand the setup can save you from potential headaches.- Experiment with Scenes: Don’t be afraid to create multiple scenes to suit different occasions. It adds a personal touch to your smart home setup.Final Thoughts The Shelly Wall Kit has exceeded my expectations. It’s user-friendly, reliable, and has seamlessly integrated into my existing smart home ecosystem. If you’re looking to enhance your lighting control without a major overhaul, I highly recommend giving the Shelly Wall Kit a try. It’s a small investment that yields big rewards in convenience and comfort.
