Forgot to mention that the thread problem is almost the times in Apple Home. In aqara I have problems with Zigbee devices randomly disconnecting and connecting again after a while.
Are the devices far apart? Otherwise there might be some interference
In general you only want to have one Thread network. That allows devices to form a mesh and extend coverage which improves connectivity… especially for devices that are further away from the hub
The IPv6 address starts with a Unique Local Address (fdxx::) prefix, so that’s perfect.
As Markus already mentioned, the problem is likely due to the distance between the devices or interference. It might help to place a smart outlet between the hubs and the devices.
For example, one like this:
However, it can only amplify either ZigBee or Thread, but not both at the same time.
Just notice that 2 of the M3 hubs have different Zigbee channels. 3 hubs have channel 11, one hub is on channel 15 and the other one is on 20. Is this a problem?
That is because each hub make his own zigbee network.usually if you just need an zigbee net work you need only one hub and zigbee bridges
What device is that?did you connected to your WiFi?as only like that it gets the IP address
That’s completely normal for a Thread device. A Thread device can have multiple IPv6 addresses, each serving a different purpose. If you want to dive into the technical details, you can check this out:
Thank you. Just trying to find a reason for my problem
Can you tell us a bit more about your setup? Maybe we’ll come up with something.
Hi again. I have a router and 7 TP link Deco S7 model in AP mode. In total I have 173 devices mostly aqara. I have 2 Apple TV, 6 HomePods, 3 Aqara hub M3, 1 aqara hub E1 and 1 aqara doorbell G410. The devices that always losing connection in Home App are the locks aqara U200, Candle warmer from Switcbot and Alpstuga Air quality monitor from IKEA.
In the aqara app I have some Zigbee problems, with some devices randomly disconnecting and connecting again after a while.
All the hubs have channel 11 for thread and also for Zigbee with an exception: 1 hub has channel 15 and the other Chanel 20 for zigbee.
