Good day everyone! What if it is not the phase that connects to the switch, but the neutral? Therefore, the phase goes to the lamp. Will this device work in this case?
@ivan1 Good day! Thank you for your intriguing question regarding the wiring setup for the Aqara Single Switch Module T1 (No Neutral). Based on the reference information, the module is designed to have the live wire (L) connected to the switch, while the load wire (L1) connects to the light. Unfortunately, the documentation does not cover scenarios where the neutral wire connects to the switch while the phase connects directly to the lamp.
Given this, it’s uncertain whether the device would operate correctly under such conditions. I recommend following the standard installation procedure as outlined, or consulting with a professional electrician to explore potential workarounds safely. Additionally, community insights might offer valuable perspectives, so feel free to share your experiences or solutions!
