Sleep mode of camera
How can I set my camera to be activated 24/24
@hintgejo To keep your Aqara camera activated 24/7, you can set it to continuous recording mode, provided that your camera model supports this feature and has an SD card inserted. Here’s how you can set it up:
  1. Insert an SD Card: Ensure your camera has an SD card installed. Most Aqara cameras support SD cards for extended storage, except for the G5 model.
  2. Select Recording Mode: Go to your camera settings in the Aqara Home app and choose the Record Continuously option. This will enable 24/7 recording.
If you need any further assistance or if your camera model has specific requirements, feel free to ask! :blush:
which camera? is doorbell G4?
@hintgejo To set your camera for 24/7 activation (continuous recording), you’ll need to use an SD card (note: most Aqara cameras support SD cards, but the G5 does not). With the SD card inserted, go to the camera settings in the Aqara Home app and select the “Record Continuously” mode. For the G4 doorbell, continuous recording is available when it’s connected to an external power source .
If you run into any issues or have more details about your specific camera model, feel free to share—we can troubleshoot together!
