I’ve been wanting to upgrade my home security system for a while now, and I finally took the plunge! My main goals were to set up a smart alarm system that could turn on my bedroom lights and turn off the fan, as well as monitor my garage door and fence gates. After doing some research, I decided to go with Hubitat as my hub since it seemed to have the flexibility I needed.
First, I started by setting up the basic alarm functionality. I connected my bedroom lights and fan to Hubitat, and after a bit of trial and error, I managed to create a routine that automatically turns on the lights and turns off the fan when the alarm is triggered. It’s such a small detail, but it makes a huge difference in the mornings!
Next, I tackled the sensor setup. I purchased some basic contact sensors to monitor my garage door and fence gates. Initially, I had some trouble getting them to pair with my hub, but after resetting them and trying again, everything connected smoothly. Now, I can keep an eye on my property from my phone, which gives me peace of mind.
One thing I learned along the way is the importance of testing your setup thoroughly. I accidentally triggered the alarm a few times in the beginning, but after adjusting the sensitivity of the sensors, everything worked out perfectly. I also found that using Hubitat’s mobile app made managing my system much easier.
If anyone is thinking about making the switch to a smart alarm system, I highly recommend starting small and gradually adding more features. It’s a learning process, but the end result is well worth it! ![]()
