Smart Bathroom Automation: My Journey to a Hassle-Free Experience
As someone who loves gadgets and automation, I’ve always wanted to create a truly smart bathroom. After some research and experimentation, I’ve managed to set up a system that not only improves my daily routine but also adds a touch of luxury to my home. Here’s how I did it!
The Problem
I’ve noticed that humidity in my bathroom can get quite high, especially after taking a shower. This not only makes the bathroom uncomfortable but also promotes mold growth. I wanted a system that would automatically manage the humidity levels without me having to think about it.
The Solution
After some research, I decided to use a combination of a Sonoff humidity sensor and a Lutron Caseta smart switch to control my bathroom exhaust fan. The goal was to create an automated system that would turn the fan on when the humidity reached a certain level and keep it running long enough to effectively reduce the moisture in the air.
The Setup
  1. Humidity Sensor: I installed a Sonoff humidity sensor in my bathroom. This device continuously monitors the humidity levels and sends data to my smart home system.
  2. Smart Switch: I connected my bathroom exhaust fan to a Lutron Caseta smart switch. This allows me to control the fan remotely and integrate it with my automation system.
  3. Automation Logic: Using Node-RED, I created a flow that monitors the humidity sensor. When the humidity level exceeds 60%, the system turns on the exhaust fan. The fan stays on for 45 minutes to ensure that the bathroom is properly ventilated. If the humidity level remains high after the initial 45 minutes, the system extends the runtime to ensure that the moisture is completely eliminated.
Additional Features
I also wanted to make sure that the system could handle different scenarios. For example, if someone manually turns on the fan, the system should still ensure that it runs for at least 45 minutes to prevent mold growth. Additionally, I integrated the system with my smart home hub so that I can monitor and control the fan from anywhere in the house.
The Benefits
This system has been a game-changer for my bathroom. It not only improves air quality but also helps prevent mold growth, which is a major concern in humid environments. The automation ensures that the fan runs efficiently without me having to manually adjust it, saving me time and effort.
Tips for Others
If you’re looking to create a similar system, here are a few tips:
  • Choose the Right Sensors: Invest in a reliable humidity sensor that can accurately monitor the moisture levels in your bathroom.
  • Use Smart Switches: Smart switches like the Lutron Caseta allow you to integrate your existing appliances into your smart home system without having to replace them.
  • Experiment with Automation: Don’t be afraid to tweak your automation settings to find the perfect balance between convenience and efficiency.
  • Monitor and Adjust: Keep an eye on your system and make adjustments as needed to ensure it continues to meet your needs.
Conclusion
Creating a smart bathroom automation system was a fun and rewarding project. It not only improves my daily life but also adds value to my home. If you’re considering a similar project, I highly recommend giving it a try. The satisfaction of solving a practical problem with technology is truly rewarding!
Happy automating! :rocket:
