I’ve been experimenting with setting up my smart blinds to open at different times depending on the day of the week. Here’s what I’ve learned and how I achieved it!
Problem:
I wanted my blinds to open at 8:00 AM Monday through Friday and at 9:00 AM on weekends. Initially, I thought of creating separate automations for each scenario, but that felt redundant and complicated.
Solution:
After some research, I discovered that using a single automation with conditional checks based on the day of the week was the way to go. Here’s how I set it up:
Identify the Days:
- Use
sun.serviceto determine the current day of the week. - Create a variable to store the day (e.g.,
monday,tuesday, etc.).
- Use
Set Up Triggers:
- Use a time trigger for 8:00 AM Monday to Friday.
- Use a separate time trigger for 9:00 AM Saturday and Sunday.
Automation Logic:
- When the trigger fires, check the current day.
- If it’s a weekday, open the blinds.
- If it’s a weekend, open the blinds an hour later.
Challenges Faced:
- Initially, I struggled with correctly identifying the day of the week. The
sun.serviceintegration was key here. - Ensuring the automation didn’t conflict with manual overrides was another hurdle, but using the
statetrigger helped.
Success Story:
Now, my blinds automatically adjust based on the day, and I no longer need to manually set them each morning. It’s a small but significant improvement to my daily routine!
Tips for Others:
- Start simple. Test each part of the automation individually before combining them.
- Use logs to debug. They helped me identify why certain conditions weren’t met.
- Don’t hesitate to reach out to the community for help. Someone has likely encountered a similar issue!
I’m excited to see how this setup holds up in the long run and maybe even expand it to include other smart home devices. If anyone has similar setups or improvements, I’d love to hear about them!
