Are there any Aqara smart buttons or does anyone has a good experience with smart buttons in this setup?
I’m really looking for some buttons next to the bed and on the hall way that work well in my setup
Hi @johan_brus
Smart button: Wireless Mini Switch – Aqara LLC
works well, supports various types of presses.
The Wireless Mini Buttons are really great and small, I use them next to the bed (under the bedside tables). The battery lasts years.
If you have a Matter-enabled Aqara hub like the M3 or M200, then Wireless Mini Buttons can be exposed as Matter button (or you can pair your third-party Matter devices with the hub).
I use the Aqara Wireless Remote Switch H1 Double Rocker. Although you can lay it flat, I prefer to mount it on the wall like a regular light switch. Otherwise, you usually end up looking for switches that are lying around. Since it runs on batteries, no wiring is required.
I have the Mini Switch T1 and the double rocker remote, and both are very solid. The Mini Switch is the one I would put next to the bed: small, with single, double and long press, and the battery lasts a long time.
Since you use M100 hubs with Homey, add the buttons to the hub first, then share them with Matter. Like cezary806 said, they show up as Matter buttons, so Homey sees the presses. Test the long press in Homey before you build everything on it.
