Smart Energy Monitoring Setup with ESP8266 and ESP Easy
I wanted to share my recent project where I set up a smart energy monitoring system using ESP8266 and ESP Easy. It’s been a fantastic journey, and I’m excited to walk you through it!
The Goal
I aimed to monitor both my whirlpool’s energy consumption and my gas usage. After some research, I decided to use an Eltako WSZ15D-65A energy meter for the whirlpool and an Elster IN-Z61 gas meter. Both devices have an S0 interface, which made them perfect for this project.
The Setup
Here’s what I used:
  • ESP8266 (I went with a D1 Wemos board)
  • Cables (nothing fancy, just some jumper wires)
  • ESP Easy for programming the ESP8266
  • MQTT Broker for data transmission
The Process
  1. Wiring: I connected the S0 outputs from both meters to the ESP8266. The setup was straightforward—just a few wires and some careful soldering.
  2. Programming: Using ESP Easy, I configured the ESP8266 to read the pulses from the meters and send the data to my MQTT broker. The community has some excellent resources, and I adapted a few scripts to suit my needs.
  3. Integration with openHAB: Once the data was on the MQTT broker, I set up some MQTT-Things in openHAB to receive and display the information. It was a matter of defining the right topics and channels.
The Results
The system has been running smoothly for a few weeks now. I can monitor both my energy and gas usage in real-time, which has been incredibly helpful. It’s also given me a better understanding of how much energy my whirlpool actually consumes!
Tips and Tricks
  • Calibration: Make sure to calibrate your meters accurately. Even a small error can lead to significant inaccuracies over time.
  • MQTT Configuration: Spend some time setting up your MQTT channels correctly. It will save you a lot of troubleshooting later on.
  • Community Resources: Don’t hesitate to look for existing projects or scripts. The community is incredibly supportive, and you can often find a solution or a helpful tweak.
This project has been a great learning experience, and I’m thrilled with the results. It’s not only helped me monitor my energy usage but also given me a deeper appreciation for the capabilities of ESP8266 and ESP Easy. If you’re looking to embark on a similar project, I highly recommend starting with the basics and building up from there. Happy tinkering!
If anyone has questions or suggestions, feel free to reach out! I’d love to hear about your projects too.
