Smart Farm Automation Success Story
I’ve been absolutely thrilled with how my smart farm automation project has come together! :star2: After months of planning and tweaking, I’ve managed to create a seamless system that handles everything from temperature control to pest monitoring. Here’s how I did it and what I’ve learned along the way.
The Setup:
I started with a basic setup using Sonoff TH Elite devices to monitor temperature and humidity. These were placed strategically around my mini farm, including the cold room and greenhouse. The goal was to automate climate control and reduce manual intervention.
The Challenges:
One of the biggest hurdles was ensuring consistent airflow in the cold room, especially during Quebec’s harsh winters. I experimented with different exhaust and intake pipe configurations and eventually settled on a system that uses smart vents controlled by Home Assistant automations. This setup not only prevents freezing but also optimizes airflow for better temperature regulation.
The Automation:
Here’s a quick breakdown of the automations I’ve implemented:
  • Warm Up: If the temperature drops below 1.0°C (33.8°F), the ceramic heater kicks in.
  • Hold Temperature: When the temperature reaches between 4.0°C (39.2°F) and 5.0°C (41°F), both the heater and exhaust fan turn off.
  • Vent: If the temperature exceeds 6.0°C (42.8°F) and it’s colder outside, the exhaust fan activates to push warm air out and pull in fresh, cooler air.
Tips and Tricks:
  1. Sensor Placement: Don’t underestimate the importance of sensor placement. I learned the hard way that sensors should be placed away from direct heat sources to get accurate readings.
  2. Regular Maintenance: Check your pipes and vents regularly to ensure they’re free from obstructions. This is crucial for maintaining airflow and preventing equipment damage.
  3. Backup Systems: Invest in a reliable backup power source. During a recent power outage, my system seamlessly switched to a generator, preventing any damage to my crops.
The Results:
The best part? My farm is now running more efficiently than ever, with minimal manual intervention. I can monitor everything from my phone, which is a huge convenience, especially when I’m not on-site.
I’m now looking to expand this system to include more advanced features like automatic irrigation and pest detection. If anyone has tips or recommendations for integrating these systems, I’d love to hear them!
Thanks to this community for all the inspiration and support. Here’s to many more successful harvests! :seedling::sparkles:
