Smart Garage Door Integration with Shelly 1 Gen4
I’ve recently embarked on a project to smarten up my garage door, and I wanted to share my journey and insights with the community. My goal was to integrate my garage door motor, a Marantec Comfort 220, into my Home Assistant setup using the Shelly 1 Gen4. I’ve heard great things about Shelly devices, especially with their support for Zigbee and Matter, so I was excited to give it a try.
First, I did some research and came across several older posts suggesting the use of a Shelly 1 with an Add-On for Reed contacts. However, since I’m using the Gen4 model, I wondered if the same approach would work or if there’s a more streamlined method available now. I reached out to the community to gather the latest recommendations and was pleasantly surprised by the wealth of information and support.
Here’s what I discovered and how I implemented it:
  1. Shelly 1 Gen4 Setup: The Gen4 model supports Zigbee and Matter out of the box, which means I didn’t need additional hardware for communication. I simply paired the Shelly with my existing Zigbee network through Home Assistant.
  2. Reed Switch Integration: To monitor the garage door’s state (open or closed), I installed a Reed switch on the door. I connected this to the Shelly 1 Gen4, which allowed me to detect changes in the door’s position without needing any extra Add-Ons.
  3. Automation in Home Assistant: Using the Shelly’s built-in automation capabilities, I set up a scene in Home Assistant that triggers actions based on the garage door’s state. For example, when the door opens, I have my smart lights turn on automatically, and when it closes, they turn off. This integration has made my garage much more convenient to use.
  4. Battery Life and Reliability: One concern I had was battery life, especially since the garage door isn’t used constantly. However, the Shelly 1 Gen4’s low-power design has been impressive. The battery life has exceeded my expectations, and the device has been reliable so far.
  5. Community Support: I couldn’t have done this without the help of the community. The tips and recommendations I received were invaluable, and it’s great to see such a supportive environment for smart home enthusiasts.
If anyone else is looking to integrate their garage door into their smart home setup, I highly recommend considering the Shelly 1 Gen4. It’s a versatile and reliable device that worked perfectly for my needs. I’d love to hear how others have approached similar projects or if there are alternative solutions that might be worth exploring!
Best regards,
