As the cold winter nights set in, I’ve been experimenting with creating a seamless nighttime routine for my smart home. The goal is to ensure energy efficiency while maintaining security and comfort. Here’s what I’ve discovered and how I’ve integrated various devices to make it work!
The Setup
I’ve been using the HMIP-PSM2 to control my TV and connected devices. The idea is to automatically cut power to these devices after a period of inactivity, especially during late-night hours. I’ve also integrated a Wyze Cam to monitor the area and ensure everything is secure.
The Challenge
Initially, I faced an issue where the PSM2 would cut power even when the TV was actively in use. After some troubleshooting, I realized the problem was with the power consumption thresholds in my automation script. The TV draws around 200W when in use, but the script was mistakenly interpreting standby mode (below 50W) as inactivity.
The Solution
I adjusted the script to better differentiate between active use and standby. Here’s a quick breakdown of the revised logic:
- Time-based trigger: Activates between 10:30 PM and 6:00 AM.
- Power consumption monitoring: If the TV is in standby (below 50W), the PSM2 waits for 5 minutes before cutting power.
- Activity detection: If any motion is detected via the Wyze Cam, the PSM2 cancels the shutdown sequence.
This adjustment ensures that the system doesn’t interfere with active use but still maintains energy efficiency during inactivity.
The Outcome
The result has been fantastic! My energy consumption during the night has reduced significantly, and I no longer worry about devices staying on unnecessarily. Plus, the integration with the Wyze Cam adds an extra layer of security, as any unexpected movement triggers an alert on my phone.
Tips for Others
- Test thresholds: Ensure your automation scripts accurately reflect the power consumption patterns of your devices.
- Combine sensors: Integrating motion sensors with power management devices can create a more robust system.
- Regular checks: Periodically review your automation logs to ensure everything is working as intended.
This project has been a great learning experience, and I’m excited to see how I can further optimize my smart home setup. If anyone has similar experiences or tips, I’d love to hear about them!
