I wanted to share my recent success in integrating multiple smart home devices to create a seamless automation system. After researching various options, I decided to combine Shelly devices, a Honeywell thermostat, and humidity sensors to automate my home’s climate control. Here’s how it all came together:1. Shelly Devices as the Backbone I started by installing Shelly switches and sensors throughout my home. Their compatibility with multiple protocols and ease of setup made them an excellent choice. Using the Shelly app, I configured each device to communicate with my Home Assistant setup. The ability to customize automation rules directly on the devices simplified the process significantly.2. Honeywell Thermostat Integration Next, I integrated my Honeywell thermostat. The Honeywell Total Connect Comfort integration within Home Assistant proved to be user-friendly. I set up the thermostat to adjust temperatures based on occupancy detected by the Shelly motion sensors. This integration ensures that the heating or cooling kicks in only when someone is home, saving energy and costs.3. Automating with Humidity Sensors To enhance comfort, I added humidity sensors in key areas like the bathroom and basement. These sensors work seamlessly with my smart bulbs and exhaust fans. I programmed the system so that if humidity levels exceed 80%, the lights and fans turn on automatically. After 15 minutes, if the humidity drops below 65%, the system turns everything off. This setup not only improves air quality but also prevents mold growth.4. The Result: A Smarter Home The integration of these devices has transformed my home into a smarter, more efficient space. The system now adapts to my lifestyle, adjusting temperatures and managing humidity without any manual intervention. It’s incredibly satisfying to see all these devices working together harmoniously.Tips for Others - Start Small: Begin with a few devices and gradually expand your setup. - Leverage Compatibility: Choose devices that are compatible with your existing ecosystem to avoid integration headaches. - Test and Adjust: Automation rules may need tweaking based on real-world usage. Don’t hesitate to experiment and refine your setup.I’m thrilled with how this project turned out and look forward to adding more smart devices in the future. Happy automating everyone! ![]()
