Hey everyone! I wanted to share my recent success with adjusting my garage door sensor using the Econolink Z-Wave Plus tilt sensor. I’ve seen a lot of discussions about fine-tuning these sensors, but I stumbled upon a method that worked exceptionally well for me and thought I’d pass it along. ![]()
Like many of you, I wanted the sensor to detect a slightly open door as soon as possible while minimizing false alarms. The key was finding a way to make precise adjustments without the usual flush mount setup. I’ve seen others use boards or metal plates to bend, but most garage doors have extra holes on the arm that attaches the opener to the door frame. That’s where the magic happened!
I attached my sensor to the side of a small piece of 2x4 and then used a bolt to secure it to the opener’s attachment arm. This allowed me to rotate the sensor on the bolt for very fine adjustments until I achieved the sensitivity I wanted. Once satisfied, I tightened the bolt to lock it in place. The result? The sensor trips before the door is even 3 inches open, and so far, no false opens either! ![]()
One tip I’d like to share is to ensure the board you use is at least as wide (or slightly wider) than the sensor. This prevents the sensor from overhanging and allows for a full 360-degree adjustment without hitting the attachment bar during rotation. Check out the pics below to see how it looks in action! ![]()
I hope this helps someone out there who’s struggling with similar adjustments. It’s amazing how a little creativity and some basic tools can make such a big difference in your smart home setup. Let me know if you’ve tried something similar or have other tips to share! ![]()
Happy automating! ![]()
