After months of planning and finally finding the time to execute, I’m thrilled to share my kitchen cabinet lighting project! The goal was to create a sleek, energy-efficient lighting solution that integrates seamlessly with my smart home ecosystem. Here’s how it all came together:
Project Overview
I decided to go with 44 feet of flexible LED strips, mounted in aluminum track for a clean, modern look. The setup includes two Fibaro RGBW controllers—one for the top cabinets and one for the bottom—managed by a custom-built control box in the cabinet above the microwave. This box also houses a Qubino 1D Flush relay with a temperature probe to manage the cooling fan and a 12V 200W power supply.
Automation & Sensors
To keep things hands-free, I installed a motion sensor in the kitchen. This not only triggers the lights but also ensures they turn off after a set period of inactivity. The RGBW controllers allow for customizable lighting scenes, which I programmed using openHAB rules. For instance, dimmer settings at sunset transition to brighter modes when motion is detected.
Challenges & Solutions
One hurdle was ensuring all components communicated smoothly. I had to troubleshoot the initial setup to ensure the Fibaro controllers and Qubino relay integrated properly with my Z-Wave network. Using Phoscon for device pairing and openHAB for rule creation was key in achieving seamless automation.
Results
The outcome is nothing short of amazing. The LED strips provide even, customizable lighting, and the motion sensor ensures energy efficiency without sacrificing convenience. The cooling fan automatically kicks in when the temperature rises, preventing any heat buildup.
Tips for Others
If you’re considering a similar project, here are a few tips:
- Plan Ahead: Measure your space carefully and decide on the placement of tracks and sensors.
- Quality Components: Invest in reliable controllers and sensors to ensure smooth operation.
- Smart Home Integration: Use platforms like openHAB or SmartThings to customize automation rules that fit your lifestyle.
This project has completely transformed my kitchen, making it both functional and aesthetically pleasing. I’m excited to explore more smart home enhancements in the future!
Here are some resources I found helpful:
Feel free to reach out if you have questions or need advice on your own smart home projects! ![]()
