Smart Home Automation Success Story: Weather Light Integration
I’ve been absolutely thrilled with my recent smart home project—a weather light integration that combines my love for home automation with my passion for local weather phenomena. As someone who grew up in Flint, MI, I’ve always been fascinated by the iconic weather ball that broadcasts the forecast through its color-coded display. When I discovered the potential of integrating this concept with Home Assistant, I knew I had to give it a try!
After several years of tinkering on SmartThings, I’ve refined the setup to be more robust and visually stunning on Home Assistant. The system now uses a weather station outside my house and a Hue Lily Light pointed at it. The integration involves multiple sensors and automations that adjust the light’s color based on the forecasted temperature and precipitation probability.
Here’s a quick breakdown of how it works:
  1. Actual High Sensor: Tracks the day’s high temperature and compares it to the forecast.
  2. Weather Light Colors: Changes the light’s color based on whether the forecasted temperature is expected to be significantly higher, lower, or similar to the actual high.
  3. Weather Light Flash: Flashes the light periodically if precipitation is predicted, using keywords like rain, snow, or thunderstorms.
The colors are even customized to match the hex codes of local sports teams and other fun references, adding a personal touch to the project.
While the setup required some trial and error, especially with time switches and NWS forecast alignment, the end result has been nothing short of amazing. My family and friends are always impressed when they see the light glowing red for a warm day or blue for a chilly one. It’s a great way to combine technology with a bit of local charm!
If you’re looking to add a unique weather display to your smart home, I highly recommend exploring this type of integration. It’s a fun project that combines sensors, automations, and creative thinking—all while keeping you informed about the weather!
Happy automating! :sun_with_face:
