I recently installed these Smart LED Ceiling Lights in my hallway, and I must say, the setup was pretty smooth. However, I encountered a small hiccup with the main bulb not turning on when triggered by my motion sensor. Let me walk you through how I resolved it and what I learned along the way.Initially, I thought the issue might be with the automation itself. I added the lights to my motion sensor automation, expecting both the main bulb and the accent ring to illuminate. But no luck—the accent ring lit up, but the main bulb stayed off. I checked my configuration and realized I might need to adjust the automation settings.After some research, I discovered that the main bulb and the accent ring are controlled separately. To ensure both turn on together, I needed to specify both commands in my automation. I updated my YAML configuration to include both the main bulb and the accent ring commands, and voilà! Everything worked perfectly.This experience taught me the importance of understanding how different components of a smart device are controlled. It also highlighted the value of diving into the documentation and community forums for troubleshooting tips. If you’re facing similar issues, don’t hesitate to reach out or share your own solutions—community support is invaluable!Here’s the corrected automation configuration I used for reference:yamlautomation: - alias: Hallway Motion Detection trigger: - platform: state entity_id: binary_sensor.hallway_motion to: ‘on’ action: - service: light.turn_on target: entity_id: light.hallway_main_bulb - service: light.turn_on target: entity_id: light.hallway_accent_ringHappy automating everyone! Let’s keep sharing our successes and tips to make our smart homes even smarter! ![]()
