Hey everyone, I recently installed some Govee LED strips in my home and wanted to share my experience and some tips for anyone looking to do the same! ![]()
First, I purchased the BTF-LIGHTING WS2811 5m 16.4ft 60leds/pixels/m 300leds IP65 Waterproof Black PCB Flexible Addressable Strip Light from Amazon. The installation process was pretty straightforward, but I did run into a few hiccups along the way. I used a NodeMCU to control the strips and configured everything through Home Assistant. Initially, I was worried about the wiring, but using jumpers made things much easier!
Here are a few tips I picked up during the installation:
- Plan your layout carefully: Measure where you want the strips to go before cutting them. I ended up having to re-cut a few sections because I miscalculated the length!
- Use heat-resistant adhesive tape: This helps secure the strips without damaging them, especially if they’re near heat sources.
- Test each section before installing: I learned this the hard way after discovering a faulty segment halfway through the installation.
- Consider using a power supply with a built-in dimmer: This gives you more control over the brightness without needing additional switches.
I also experimented with different color configurations and was amazed at how versatile these strips are. They’ve completely transformed the ambiance of my living room! ![]()
One thing I’m still figuring out is how to sync the strips with my Alexa voice controls. I’ve set up some basic routines, but I’d love to automate more functions. If anyone has tips on integrating LED strips with smart assistants, I’d love to hear them! ![]()
Overall, I’m super happy with how the project turned out. It was a bit of a learning curve, but definitely worth the effort. Happy installing, everyone! ![]()
