Hey there, I’ve been tinkering with my smart LED strip setup and ran into a bit of a mystery. I’ve configured two scenes for my LED strip: one for warm lighting in the evening and another for a cooler, brighter daylight setting. The warm scene works perfectly, but when I try to activate the cold scene, the strip turns almost red instead of the crisp white I expect.
Here’s what I’ve done so far:1. Created both scenes through the UI.2. Verified the correct settings manually by checking MQTT data for RGBW, HS, and other parameters.3. Manually entered the data into the scenes.yaml file.Despite all that, the cold scene doesn’t behave as expected. The strip ends up with a reddish hue instead of the cool white I set. I’ve double-checked the color modes and brightness settings, but nothing seems off. It’s strange because the warm scene works flawlessly, so the strip itself must be functional.I’m wondering if there’s something specific about how the cold scene is configured that’s causing this issue. Maybe there’s a setting or parameter I missed when defining the cold scene? Any insights or suggestions would be greatly appreciated!
If anyone else has encountered a similar issue or has tips on troubleshooting LED strip scenes, please share! I’m eager to get this sorted out and make the most of my smart lighting setup. Let’s see if we can crack this together! ![]()
