Smart Lighting Automation: A Smooth Setup Journey
I recently set up a smart lighting system in my living room using Eugene’s Wi-Fi sensors for presence detection. My goal was to automate the lights so they turn on at sunset when the blinds close and turn off when no one is in the room. Here’s how I did it and what I learned along the way!
I created a system variable called ‘LivingRoomOccupied’ controlled by a program named ‘LivingRoom_Active’. The logic is simple: if there’s no movement detected on either side of the room or the noise sensor (which detects the TV) doesn’t pick up anything for 15 minutes, the variable turns false, and the lights should turn off. However, I noticed a strange issue where the lights would sometimes turn off even when the TV was on and the noise sensor indicated activity. This was puzzling because the system variable ‘LivingRoomOccupied’ wasn’t switching to false as expected.
After some troubleshooting, I discovered that the program responsible for turning off the lights was triggering based solely on the motion sensors, not the noise sensor. It turned out that both motion sensors needed to detect no movement for 15 minutes before the lights would turn off, which wasn’t what I intended. This was a bit frustrating, but it taught me the importance of thoroughly testing each component of my automation setup.
To resolve this, I adjusted my program to consider both motion and noise sensors more effectively. Now, the lights stay on when the TV is playing, and they only turn off when there’s truly no activity in the room. This adjustment made a huge difference in how smoothly the system operates.
Reflecting on this experience, I realize how crucial it is to understand each device’s behavior and how they interact within the automation ecosystem. It’s a learning process, but seeing the system work perfectly now makes it all worthwhile. If anyone has tips or tricks for optimizing their smart lighting setups, I’d love to hear them!
