I recently dove into the world of smart lighting automation with Home Assistant, and I wanted to share my journey and insights with the community. My goal was to create a system that adjusts lighting based on natural light and occupancy, and I must say, it’s been a rewarding experience!
The Setup
I started by integrating a motion sensor and a light sensor into my setup. These sensors measure brightness and detect movement, which are crucial for automating the lights. I also customized the delay time for turning off the lights, the brightness levels, and the color temperature to match my preferences.
The Automation Script
Here’s a glimpse of the script I used. It automatically adjusts the lighting based on the time of day and the amount of natural light in the room:
yaml
alias: ‘Lighting Automation’
trigger:
- platform: state
entity_id: !input motion_sensor
to: ‘on’
condition: - condition: state
entity_id: !input light_entity
state: ‘off’ - condition: or
conditions:- condition: sun
after: sunset - condition: numeric_state
entity_id: !input lux_sensor
below: !input lux_threshold
action:
- condition: sun
- choose:
- conditions:
- condition: sun
after: sunset
sequence: - service: light.turn_on
data:
brightness_pct: !input brightness_eind
color_temp: !input color_temperature_eind
transition: 3
- condition: sun
- conditions:
data:
brightness_pct: “{{ (states(‘sensor.’ + lux_sensor) | float / lux_threshold * (brightness_eind - brightness_start) + brightness_start) | round(0) }}”
color_temp: “{{ (states(‘sensor.’ + lux_sensor) | float / lux_threshold * (color_temperature_eind - color_temperature_start) + color_temperature_start) | round(0) }}”
transition: 3
- conditions:
- delay: ‘00:{{ states(‘input_number.lighting_delay’) | int }}:00’
- choose:
- conditions:
- condition: sun
above: sunset
sequence: - service: light.turn_off
data:
transition: “{{ ‘00:00:’ + states(‘input_number.light_off_transition’) }}”
- condition: sun
- conditions:
above: 1
data:
transition: 3
- conditions:
Challenges and Solutions
One challenge I faced was ensuring smooth transitions between different lighting conditions. I found that adjusting the brightness and color temperature gradually made the system more comfortable. Another thing I learned was the importance of proper sensor placement to avoid false triggers.
Conclusion
This setup has significantly improved my home’s energy efficiency and comfort. It’s amazing how technology can adapt to our natural environment! If you’re considering similar automation, I recommend starting with a simple script and gradually adding more features as you become comfortable.
I’d love to hear about your experiences with smart lighting automation or any tips you might have! Let’s continue to innovate together! ![]()
