Smart Lighting Automation: My Journey from SmartThings to Hubitat
As I embark on this exciting journey of migrating from SmartThings to Hubitat, I wanted to share my experiences and insights with the community. The transition has been both challenging and rewarding, and I hope my story can inspire or assist others who are considering a similar move.
One of the most seamless transitions has been setting up my smart lighting automation. I’ve been using an Inovelli switch to control three Zigbee LED strips, and while the automation worked flawlessly in SmartThings, I’ve encountered some quirks in Hubitat. For instance, setting the light level correctly has been inconsistent—90% of the time, the level isn’t set properly, although once the light is on, subsequent adjustments work without issue. This has led me to explore different automation settings and troubleshoot potential device log issues.
To address these challenges, I’ve been experimenting with adjusting the automation rules within Hubitat. I’ve found that manually triggering the automation after the initial setup helps ensure the light levels are set correctly. It’s a minor inconvenience, but it’s a workaround that keeps my lighting automation functional while I continue to refine the setup.
Another aspect I’ve been exploring is integrating my Google Home devices with Hubitat. While there are a few hiccups, such as the occasional delay in scene execution, the integration has been mostly smooth. I’ve particularly appreciated the ability to create and trigger scenes directly from my Google Home, enhancing the seamless experience of controlling my smart home.
For those considering a migration to Hubitat, I’d recommend starting with a few key devices and gradually expanding your setup. This approach allows you to iron out any issues before fully committing to the ecosystem. Additionally, leveraging the wealth of resources and community support available has been invaluable in navigating the transition.
As I continue to explore the capabilities of Hubitat, I’m excited about the potential to further enhance my smart home setup. Whether it’s refining my lighting automation, integrating new devices, or discovering innovative ways to use the platform, the journey is as rewarding as the destination.
Thank you to everyone in the community for your support and shared knowledge. Here’s to many more fruitful explorations and successful projects ahead!
