I’ve been experimenting with setting up a smart lighting system in my home, and I wanted to share my experiences and some tips that might help others. My goal was to create an automation that notifies me if there’s motion detected in a specific room after I close the door. I’m using a motion sensor and a door contact sensor for this setup.
Initially, I set up a rule that triggers a notification when the motion sensor is active and the door contact is closed. However, I ran into an issue where the rule would trigger immediately as I was shutting the door because the motion sensor was activated during the door closure. This was frustrating because I wanted the notification only if there was unexpected motion after the door was closed.
After some research and troubleshooting, I discovered that adding a delay to the rule would solve the problem. The delay ensures that the initial trigger caused by the door closure doesn’t immediately set off the notification. Instead, it waits for a specified period before checking if the conditions are still met.
Here’s how I implemented the solution:
- Identify the Delay Duration: I started with a 10-second delay, which seemed reasonable for my use case. This allows enough time for the motion caused by closing the door to subside.
- Modify the Rule: I updated the rule to include the delay before checking the motion sensor and door contact status. This ensures that only sustained motion after the door is closed triggers the notification.
- Test the Setup: I tested the rule multiple times to ensure it worked as intended. The delay prevented false triggers, and I received notifications only when there was actual motion after the door was closed.
This experience taught me the importance of considering all possible triggers when setting up automations. Adding a simple delay can make a significant difference in the reliability of the system.
If anyone has similar issues or suggestions for improving this setup, I’d love to hear your thoughts! Let’s continue to learn and grow together in the smart home community. ![]()
