Smart Lighting Automation with Motion Sensors and Fade Effects
Hey everyone, I’m really excited to share my latest project with the community! I’ve been working on creating a smart lighting system that not only detects motion but also provides visual feedback before turning off. This idea came to life after I noticed how inconvenient it was to rely solely on motion sensors without any indication of the lights about to shut off. Let me walk you through my setup and the challenges I faced along the way.
The Setup
I’m using an AEOTEC TRISENSOR 8 motion detector paired with a PHILIPS HUE GU10 bulb. The goal is to have the lights turn on at 100% brightness when motion is detected. After 5 minutes of inactivity, the brightness should fade down to 20% as a warning signal before turning off completely 30 seconds later. Sounds simple, right? Well, the tricky part was ensuring the timer resets every time motion is detected, even if the lights are already in the fade-down phase.
Challenges and Solutions
At first, I struggled with the flow logic. Every time motion was detected during the fade-down period, the lights would still turn off after the initial 5-minute timer. After some research and experimentation, I realized I needed to use virtual variables to track the state of the lights and reset the timer dynamically. This approach allowed me to create a seamless experience where the lights adapt to real-time motion detection without any lag.
Key Takeaways
  1. Use Virtual Variables: They are incredibly useful for tracking states and resetting timers on the fly.
  2. Test Incrementally: Start with basic on/off functionality before adding fade effects. This helps identify issues early in the process.
  3. Documentation is Your Friend: Keep detailed notes of your configurations and test results. It saves time in the long run!
Community Feedback
I’d love to hear how others have tackled similar projects. Have you implemented any unique solutions for motion-activated lighting? Let me know your thoughts and experiences below!
Cheers,
