Smart Lighting Automation with Z-Wave Dimmer
I recently upgraded my kitchen lighting setup and wanted to share my experience with the community. I have seven halogen bulbs controlled by a Z-Wave dimmer, which works perfectly. However, I also have two GU10 bulbs in the same area that I wanted to integrate into the same system. Initially, I faced a challenge because the dimmer couldn’t handle different loads, but I found a workaround using Home Assistant (Hass.io). By setting up the brightness level from the Z-Wave dimmer as a trigger, I can now control the GU10 bulbs seamlessly. This integration has made my kitchen lighting much more versatile and user-friendly. If anyone has similar setup questions or needs help with their own automation projects, feel free to reach out! :rocket::sparkles:
