Hey everyone, I wanted to share some tips and experiences regarding setting up smart lighting groups in Home Assistant. I recently went through the process of grouping multiple lights (both Wi-Fi and Zigbee) to control them with a single button press, and it was a bit of a learning curve. Here’s what I discovered:
Grouping Methods: I tried using the built-in light group helper in Home Assistant, which worked well for most lights. However, one of my Wi-Fi lamps wouldn’t turn off when using a physical button (IKEA Styrbar), even though it worked perfectly with the dashboard button. It turns out the issue was with how the commands were being sent over the network. I had to adjust the configuration to ensure all devices received the command simultaneously.
Reliability: Sending separate commands to each lamp might seem redundant, but it actually improved reliability. I set up a script that sends the same on/off command to each light individually, ensuring no light is left behind. This approach was more reliable than relying on the group function alone.
Testing and Tweaking: I learned the importance of thorough testing. I tested each light individually and as part of the group to identify any problematic devices. This process helped me isolate the issue with the Wi-Fi lamp and adjust the setup accordingly.
Documentation: Keeping detailed notes on each device’s behavior and configuration was invaluable. It helped me troubleshoot faster and understand why certain devices acted differently.
If anyone else is working on a similar project, I highly recommend starting small, testing each component, and gradually scaling up. It might take a bit more time upfront, but it pays off in the long run with a more reliable system.
Any other tips or experiences from the community? I’d love to hear how others have tackled similar challenges!
