Smart Lighting Project: Challenges and Solutions
Hey everyone, I wanted to share my recent experience with setting up a smart lighting system in my home. I’ve been using the Lightify RGBW spots for a while now, and they’ve been a great addition to my SmartThings setup. However, I ran into an issue that I thought I’d document in case others are facing the same problem.
So, the challenge: I have several RGBW bulbs, and while they work great individually, controlling them as a group has been a bit of a pain. Each bulb requires manual adjustment in the app, which can be time-consuming and frustrating, especially when trying to match colors. My goal was to find a way to group these devices so that controlling one would control them all.
I considered a few options. One idea was to use IFTTT or another automation service, but I wasn’t sure how well that would integrate with my existing setup. Another thought was to dive into some coding, but my skills are a bit rusty, and I wasn’t sure where to start. Then, I stumbled upon a forum post suggesting the use of a third-party app to create virtual devices that act as a hub for multiple bulbs.
After some research, I found a solution that worked perfectly. I used a combination of the SmartThings app and a third-party automation tool to create a virtual switch. This switch acts as a master controller, sending commands to all the RGBW bulbs at once. It was a bit of a learning curve, but the end result was worth it!
Here’s what I did:
  1. I created a virtual device in the automation app.
  2. I programmed it to send the same color and brightness commands to all the bulbs when activated.
  3. I linked this virtual device to a button in the SmartThings app for easy access.
The best part is that I can now control all my bulbs with a single tap, and they stay perfectly synchronized. It’s been a huge time-saver and has made my home lighting setup much more enjoyable.
I’d love to hear if anyone else has tackled a similar issue or has tips for improving this setup. Happy smart lighting!
