Hey everyone, I wanted to share my recent success in setting up a smart lighting system using a mix of Philips Hue bulbs and Fibaro motion sensors. It’s been a rewarding project, and I thought I’d walk through my journey in case it helps others!
The Goal:
I aimed to create a seamless lighting system that automatically adjusts based on occupancy and time of day. The idea was to enhance comfort while ensuring energy efficiency.
The Setup:
I started by installing Philips Hue bulbs throughout my home. These were chosen for their compatibility with Alexa and wide color range. Next, I added Fibaro motion sensors in key areas like the living room and hallway. The sensors were placed strategically to cover maximum movement areas without overlapping too much.
Integration with Alexa:
Using Alexa routines, I programmed the lights to dim when no motion was detected for 10 minutes and brighten upon detecting movement. This was a bit tricky at first, but with some trial and error, I got it right. I also set up a nighttime routine where the lights dim to 30% at sunset and turn off completely at 11 PM.
Challenges and Solutions:
One issue I faced was the sensors occasionally triggering false positives, especially near windows where pets would pass by. To resolve this, I adjusted the sensor sensitivity and placed them slightly higher. This significantly reduced false triggers.
Another challenge was ensuring consistent connectivity. I found that placing the sensors closer to the hub helped, but I also had to update the firmware on my hub, which the community forums suggested. This made a world of difference!
Tips for Others:
- Placement is Key: Take time to position sensors correctly. They should be high enough to avoid pets but low enough to detect human movement.
- Firmware Updates: Regularly check for firmware updates for your devices and hub. These often resolve connectivity and performance issues.
- Routine Testing: Don’t hesitate to test routines multiple times. What seems logical on paper might need tweak
Outcome:
After a week of tweaking, the system works beautifully. The lights now adjust seamlessly, providing the perfect ambiance without any manual intervention. It’s been a fantastic way to enhance my home’s comfort and efficiency.
I’d love to hear about others’ experiences with similar setups or any tips you might have. Happy smartening everyone! ![]()
