Smart lock U200 - problem with first setup, can't pairing
Hi, i bought in official store new smart lock AQARA U200. I can’t pair this device. When i press Set button led is bliking red light twice and sounds beep. Keypad can’t connect to the device. When i turn on keypad, device speak “Pleas scan the setup code… connection failed”. I tried to reset keypad, i pressed lock and acceptance button, but is no working. I hold very close keypad and nothing happend. When i scan MagicPair Code, application can’t find the device. Reset button doesn’t work. I trried to press once, twice, hold for 5,10,15,30,60 seconds. Nothing working. Led diod isn’t light. What can i do?
Have you tried holding lock and confirm for 3s on the keypad? It’s another way of resetting the lock.
If the keypad says that you need admin figerprint to reset then it means that the U200 was actually used/not factory reset correctly
Hello, welcome to the forum. Here you can find the installation process of the U200. Mastering the Installation of the Aqara Door Lock U200: Step-by-Step Guide
Mastering the Installation of Aqara U200: A Step-by-Step Guide
I tried that, but all time keypad says the same statement.
I saw that and i done this correctly. But i have firmware problems, with pairing / add do app / connecto to keypad.
If I were you, I would either contact the Aqara support, or just return it
You can also show us a video of your binding/ installing… maybe we see something
