I have installed two Smart Lock U300. They are great. I love how solid they feel, having replaced some older Yale smart locks. Definitely an upgrade in the build alone.
But, as we all know, there is no inside little knob to turn and “lock” the door. I made a feature request, but I’m curious what others think here.
The passthru button on top inside. Does anyone use it for its intended purpose? I would love to see that button customizable to do any number of options. For example, a double-press might lock/unlock the door.
The lock is fairly sophisticated, so I assume it could recognize a double-press or a long press.
I have two U300s installed and will install a third one later this year. I use the passthru button regularly. I installed one of the locks on my back door, and when working in the backyard I go back and forth with items in my hand and don’t want to have to use the fingerprint or enter the code. We also use the passthru mode when entertaining guests to avoid having to provide a guest code for entry. Hope this helps.
In the initial product design, this button was only used as a passage mode button, without considering the customization function, and now it will be more difficult if it is adjusted. But we have received your feedback, and in future product design, we will try to design such a function
I was hoping to not have to either buy new locks again. To me, the only solution would be to use something like a flic button on the door. Seems dumb to have to introduce more complexity. I think the initial assumption that people leave their doors locked all the time as a bit off. Yes, a lot of you use passage mode as intended and I completely understand the use case. However, I truly believe there is a decent sized group out there who would like the button for another use, like a “manual” lock and unlock.
I 100% agree with your feature request. In the mean time, I find that using Siri is a good solution:
“Is the garage door locked?”
“Lock (/unlock) the garage door.”
I also like to use Siri to unlock the door from my car as I arrive, or lock the door as I depart (since I have a delay set before auto-lock). I get a notification to confirm that the door actually did lock/unlock.
Obviously, this requires Apple HomeKit and the iPhone Home app. I’m guessing the same functionality is available to Android users.
I would upvote this feature request as well for the U300. The simple change, in my opinion, is to have an option to allow the user to turn off the need to verify passage mode using passcode/fingerprint.
