Hello everyone, I hope this message finds you well. I’ve been experiencing some trouble with my Smart Motion device, and I wanted to share my experience and see if anyone else has encountered similar issues or might have some advice to offer.
So, the problem I’m facing is that the Smart Motion sensor seems to be triggering alerts even when there’s no actual movement detected. It’s quite frustrating because it’s leading to unnecessary notifications and a bit of confusion around the house. I’ve tried the factory reset process to see if that would resolve the issue, but unfortunately, after resetting, the device is stuck in a loop and won’t let me complete the setup properly.
I’ve followed the troubleshooting steps provided in the user manual, including checking the placement of the device, ensuring there’s no obstruction, and verifying the connectivity with the hub. Everything seems to be in order on that front, which makes the issue even more puzzling.
I’m wondering if others have had similar experiences with the Smart Motion or other motion sensors. Have you encountered situations where the sensor becomes overly sensitive or unresponsive after a reset? If so, how did you manage to resolve it? Any insights or tips would be greatly appreciated.
In the meantime, I’ll continue to experiment with the placement and settings of the device to see if I can find a workaround. I’ll also reach out to the manufacturer’s support team to see if they can provide any additional troubleshooting steps or firmware updates that might address the issue.
Thank you all for your time and assistance. I look forward to hearing from you and hopefully finding a solution to this problem!
Best regards,
