Smart Plug Runtime Issue
I recently came across an interesting issue with my smart plug, and I wanted to share my experience and thoughts with the community. I have a portable air conditioner plugged into a smart plug, and after using it for about 6 hours in a day, the plug reports a runtime of 16.6 hours. This is puzzling because the actual usage doesn’t match the reported runtime. Additionally, the weekly usage only shows 9.03 hours, which doesn’t add up with the daily readings.
I started by checking the plug’s settings to see if there was any misconfiguration, but everything seemed fine. I also considered the possibility of a firmware issue or a miscalculation in the plug’s software. Maybe the plug is counting standby time or some other inactive period as runtime? I’m not entirely sure.
To troubleshoot, I decided to monitor the plug more closely. I set up a simple spreadsheet to track the actual usage hours and compare them with the plug’s reported data. After a week of monitoring, I noticed that the discrepancy remained consistent. This made me think that the issue might be more systemic rather than a one-off glitch.
I reached out to the manufacturer’s support team, and they mentioned that the plug uses a sophisticated algorithm to estimate runtime based on power consumption patterns. However, they admitted that there could be inaccuracies, especially with devices that have varying power draw. This explanation made some sense, but I’m still curious about how to get more accurate readings.
In the meantime, I’ve started using a separate power meter to cross-verify the plug’s data. While this isn’t a perfect solution, it gives me a better understanding of my energy usage. I’m also considering reaching out to other users who might have encountered similar issues to see if there’s a community-driven fix or workaround.
If anyone has experienced something similar or has any insights into this matter, I’d love to hear your thoughts! Maybe together we can figure out a way to improve the accuracy of these smart plugs.
Happy tinkering everyone! :rocket:
